Tinuts
Wham Bam Helmet Cam
- London, UK.
I recently reported an incident to http://www.met.police.uk/roadsafelondon/.
You can view the video here:
View: http://www.youtube.com/watch?v=j0z4JIBln8s
I got a swift reply:
Many thanks for this notification.
I have viewed the video footage of this incident and subsequently invited other officers to give an opinion. The concensus was that the man's driving was not unreasonable in the circumstances but his subsequent ranting was.
As there was well over a cars width of unobstructed road to your left, you could have been further to the left as mentioned in Highway Code Rule 160 which says;
'Keep to the left, unless road signs or markings indicate otherwise. The exceptions are when you want to overtake, turn right or pass parked vehicles or pedestrians in the road.'
S. 78 Highways Act 1835 creates an offence of 'Interrupting the free passage along a highway'. This legislation is used (rarely) to deal with a moving obstruction such as a cyclist riding far from the left and preventing a motor vehicle from passing and this is worth bearing in mind should traffic build up.
I am aware that a cyclist needs to be sure an overtaking car will not squeeze them into the kerb and I accept temporarily restricting an overtake until a wide enough gap is found is self-preservation but, in this case, there was plenty of room to allow the overtake.
A letter will be sent to the driver regarding his behaviour.
All the best
Matthew Brimilcombe
A/Inspector
Roadsafe London
This is my reply to Matthew Brimilcombe:
Hi Matthew
Thanks for your swift reply and for deciding to contact the subject of my complaint about his behaviour.
I have to say though, that I disagree somewhat with your interpretation of the law.
Highway Code rule 163 states:
163
Overtake only when it is safe and legal to do so. You should
not get too close to the vehicle you intend to overtake
use your mirrors, signal when it is safe to do so, take a quick sideways glance if necessary into the blind spot area and then start to move out
not assume that you can simply follow a vehicle ahead which is overtaking; there may only be enough room for one vehicle
move quickly past the vehicle you are overtaking, once you have started to overtake. Allow plenty of room. Move back to the left as soon as you can but do not cut in
[Picture of suggested overtaking distance]
As you can see 21s into the video I am actually cycling just inside the bus stop (once I've cleared the area covered by the central island) and not impeding the driver's progress at all. As I point out, there is no oncoming traffic so the driver should have given me (as stated in Rule 163) at least as much space as a car by pulling into or, at least, over towards, the opposite lane. He did not do that, nor did he use his indicator to announce his intention to overtake (as also stated in Rule 163). In fact, he passed me dangerously closely. I could have reached out and touched his car as he passed.
You will also notice that the bus stop I am cycling through is quickly followed by a restricted parking zone. I cycle this road regularly and there is often stationary traffic parked there. As I had to wait for the bus to pass this area before it became clear whether it was occupied it was quite prudent, and totally acceptable, for me to continue my line to avoid any problematic weaving in and out between potential parked cars. As cyclists have to be constantly alert to the possibility of motorists opening doors of parked cars directly in their path (which, although not uncommon, is also illegal) my keeping the given line until I was able to establish the level of occupancy of the parking zone is doubly understandable.
I find it somewhat surprising that, given that the government sanctioned Cyclecraft publication makes it clear that it is perfectly acceptable for cyclists to take up as much space on the road as necessary to ensure their safety, you and your colleagues fail to find the driver's behaviour unreasonable when he:
failed to give adequate distance while overtaking - which he is required to do.
very obviously overtook dangerously close in an attempt to intimidate another road user
failed to indicate his intention to overtake.
undertook me (again dangerously close and in my lane) after I set off from the ASL area at the lights, despite my being in the correct lane for a forthcoming right turn.
At no time during my passage could it be construed that I was interrupting free passage along the highway. I was not even cycling in the middle of my lane, let alone "the middle of the road" as alleged by the motorist in the video. I think you will find that the legislation to which you refer only applies when preventing motor vehicles from passing. As, to repeat myself again, there was no oncoming traffic there was nothing preventing the driver from carrying out a safe and legal overtaking manoeuvre rather than the dangerous attempt to intimidate which he actually effected.
Finally, I have to say that I'm extremely surprised by your last comment:
Perhaps, given the reasons stated above explaining my road positioning (all perfectly acceptable according to the aforementioned Cylecraft) and given the fact that there was nothing preventing a legal overtake, you could explain in what way I am failing to allow an overtake. As far as I'm aware, there is no legislation forcing cyclists, or any other road users for that matter, to give way to traffic behind them. Had I, for example, been driving a tractor (which would quite possibly have been travelling slower than my speed) or, say, a horse, I would not have been obliged to pull over and allow a single motorist to pass on this straight stretch of road, where visibility of traffic in the oncoming lane is good, so why should a cyclist travelling in a safe and legal manner be any different?
I'm curious as to whether any of the colleagues to whom you showed the video are, themselves, cyclists on London's roads. If not, I feel you should certainly open up your viewing audience to include some!
To this end, I will be posting your letter and my reply on a prominent cycling forum (http://www.cyclechat.net/forums/forumdisplay.php?f=11) so that we can widen the debate a bit. Who knows, I may be entirely wrong in my interpretation of road traffic law, but at least we will find out what other commuting cyclists think!
Best wishes
Despite the very gratifying fact that the subject of my vid will receive a letter from the Met regarding his dismal behaviour, clearly there is a difference of opinion here when it comes to interpretation of traffic law - one which, I have to say, I find surprising!
I'm quite prepared to admit my own particular reading of the law could be erroneous so I'd love to know what other CCers think.
Apologies for the long post but I feel that, given cyclists in London (and, I hope, the rest of the country soon) now have avilable to them a means of reporting poor driving relatively quickly it would be a shame if it didn't quite live up to expectations.
All the best
Matthew Brimilcombe
A/Inspector
Roadsafe London
Hi Matthew
163
Best wishes
