Only ever experienced brake fade from overheating disc brakes with small rotors ?, main disadvantages are if you grab a handful you can easily lock up , or pad availability while on tour,
These Q&A covers most http://www.mtbr.com/discbrakesfaqcrx.aspx#equipment
Sounds like a plan!You just need to go a bit faster and use the brakes a bit less
I have never run out of range and I do some fairly technical riding in places like the Lakes, Yorkshire and Peak District to the point where I have blued the rotors a number of times from the length and strength of braking. How many turns of the caps do you have from fully out to where they are clamped on the rotor? If its not many then you might try the following. Dial the cap in one turn, then open the bleed nozzle, let the excess fluid out, then tighten it up again. That will reset the "brakes off" point to one turn in rather than fully out and give you an extra turn of adjustment when they heat up. You can do more than one turn if you want. The only limit is having braking available when you go out and its a cold day - especially with winter coming and leaving some to be able to adjust for pad wear.
I get it! In fact, I almost did end up with a permanent scar on one calf. I was amazed at how hot the rotor had got.
There,s the TRP parabox that uses your existing leversHydraulic brakes aren't available for drop handlebars.
My Top Ten Disadvantages:
iii. wheel strength -dished wheels necessary for disc hubs inherently make for a weaker wheel
and as a slight side issue, sometimes the thing has to be dished more than you need - I've got a very solid late 90s steel hybrid I use as a tourer sometimes - 7-speed cassette and it performs just fine with only very occasional walking up the steepest of hills when fully loaded - but because decent 7-speed freehubs can no longer be had, its handbuilt wheels had to be over-dished only for me to then put a spacer on to accommodate the 7-speed cassette. grr, madness I tell you(The more gears on the cassette naturally increasing the gap from drop-out to spoke-ring, shortening the spokes even more, as a result the wheel’s spoke tension (left to right) is not balanced, making the wheel weaker than one with a hub gear)
Not strictly true. One of our tandems has an undished derailleur rear, with a disc. I agree it's rare.Any derailleur based wheel is dished, be it disk or rim brakes.
