400bhp
iI don't see your point! Can you elaborate/clarify?
I guess he means the big sticky out bits on the disc and mechs.
A disk break should give more "feel" than a rim mounted brake. If you have more feel you can stop quicker. If you can stop quicker you can leave your braking later. If you brake later you save more time. In my opinion you would save more time braking later, than you would gain by having a few hundred grams weight saving.
braking force is not an issue with road bikes - you already have all the power and modulation required..
on good calipers/pads it doesn't actually make much difference - I'd be more worried about losing grip under braking on a day like this...
To be honest, most brakes are 'good' if set up properly, with decent pads. Unless the pads are really poor, the limiting factor will usually be tyres...
So, you are saying in adverse weather braking force isn't an issue with most caliper brakes.
Do you ride in the rain, and particularly in rainy conditions down hills? If you do, can I borrow your bikes please![]()
I'm not saying that performance is not affected in the rain. But I am saying that even with good calipers and pads, tyres are still the limiting factor. I have Force calipers on my best bike (with replacement pads) and £15-a-set Miche calipers (also with replacement pads) on my winter bike (which is ridden is all weathers - including rain, obviously). I can still lock the wheels in a downpour if I need to. Miind you, I don't weight 20 stone...
Perhaps that needed wording differently then.
I'll let you off, we all makes mistakes.
I was out with another forumite a month or so ago and I only had the use of my shatty avid disc brakes 26"er whilst he was on his road bike. The weather was a bit dodgy. I was struggling to keep up apart from one particular downhill section when were dropping off a climb, through the trees. The disc brakes made a clear difference.
I don't know the answers
I would say frontal area of the disc is small and the mechanism could be mounted behind the fork, maybe? So at low yaw angles the effect may indeed be very small! The effect at different yaw angles is something I have no idea about.
Bike frames are constantly evolving and they will continue to do so, either with the arrival of disc brakes or without.
