Profpointy
You only need localised heat enough to form bubbles inside the caliper to bugger up brakes to near zero. You don't have to boil the whole lot. Bear in mind motorcycle brake discs can get far too hot to touch - above boiling water easiliy from a a couple of quite modest stops and I dare say the weight of caliper is in proportion with the extra weight of bike, so not wholly an invalid comparison. I dare say it's not a huge issue on motorbike nor pedal bike if used reasonably, but I'd not dismiss it quite so glibly
Pale-riders got me curious now. Got to do some sums.
Lets say heat capacity of water is 4J per K per cc. Let's also say you're riding down an alpine descent at 30C in the Summer, so 70 C to go before water boils. Proper brake fluid will boil rather higher temp, but will probably also need less heat per degree temp rise.... Let's say there's 5cc of fluid within the caliper that heats up together, so to boil a caliper's worth of fluid requires 70 x 4 x 5 Joules = 1400 Joules. Add the capacity of the caliper itself - aluminium 1 joules per gramme per K - maybe 100g for a caliper, so that's another 700 Joules needed. The iron disc itself .5 J per g per K - say another 100g item, so that's 350 more .
So total energy required is are 2500J to get a modest volume of fluid to boiling temperature.
Energy to be dissipated per meter descended = mgh so for a 120 kg bike & rider & luggage (big lad touring say) that's 1200 Joules to be used for each metre descended.
Now there are frictional losses in the above - so maybe 600J only to be lost via the brakes by braking - for each metre of descent.
And the brakes themselves are designed to lose heat as fast as possible, so if we brake gently we'll be fine.
Still - the heat in and too much heat figures are not that wide apart - so I'd say if you braked like a gorilla down a step hill in hot weather, boiling the fluid might not be out of the question.
That was fun wasnt' it?
PS there could easily be a howler in the above calc somewhere.
