Disc brakes
Snorrarcisco
Regular
Kent
Black Friday mistakes...
Well I did manage to get some wheels for my build. Some shimano rx31 they were on offer so it was sort of the cheaper ones i could find. I ended up following some advice and got some trp spyre disc brakes but here is the catch the rotors are 6 bolt but the wheel isn't. It has the shimano centre lock. It seems I need to change for the centrelock disc rotors. Now here is the catch will the spyre brakes work with the centre lock one?
Sorry for the question Disc brakes are a mystery !!!!
They'll work. At least, my TRP Spyres are fine with Shimano centrelock rotors. I believe you can get centrelock to 6-bolt converters, but getting the rotors seems a better idea (in that the centrelock attachment is arguably better, and certainly easier, than the 6-bolt one).
Rotors are rotors. The only issue I have with centrelock is when the rotor starts to rock on it's spline. You have to cinch down the locknut a bit harder.
