skwerl said:don't shop at Halfords
User3143 said:You mean to tell me you ride like ''a piranha out on the street'' but do not know to adjust a disk brake. GTFO Amateur
skwerl said:in all seriousness and as an attempt to help you shed your troll reputation:
when you say it's rubbing how bad is it? If you spin the wheel does it grind to a halt quickly? or is it just making a slight grinding noise?
they work the same way as car brakes (assuming they're hydraulic and I think yours are - haven't checked) in that when you release the lever the pads back off slightly as the pressure is relieved but they are supposed to sit in minimal conatct with the discs. spin a car wheel and you'll hear light rubbing also.
if, on the other hand, the wheel grinds to a fairly quick halt then it would be because the caliper is binding on it's runners and not backing off
