PaulSB
- Chorley, Lancashire
Our spinning arms block with small pieces of eggshell. Put the arm under a tap while holding level and let water flow through from the central inlet.
You may see some of the small outlet holes do not have a steady flow. Investigate each one carefully. Tip the arm at an angle and run water through it. On our arm this sends the debris to the last outlet hole. I then pick out the eggshell, it's usually this, with a pin. Repeat on both sides till you have a nice even flow from all outlet holes.
Must say the blowing I did left me feeling quite dizzy
