swee'pea99
Needless to say the rest is equally worn - teeth on the sprocket pretty spike-like, chain maybe 1/8" over the 12" mark, but...it all still works, fine. So should I change it? Or just not fix it on account of it's not broke?
I am running fixed, but is the chain any more likely to jam or come off? I'm not being contrary for the sake of it; I'm just not sure what I'd actually gain by not 'running it into the ground'? Obviously I'm not interested in compromising safety, but is safety at issue? Like I say, it still rides fine, and I make sure to keep the tension ok. So...is there a downside?If running fixed gear, get it changed. You can have a nasty accident if the chain jammed or came off at speed.
Ooh. Now that gets my attention! How to you decide when to change them now?I stopped running fixed chains into the ground many years ago when I broke one, spectacular but fortunately at low speed, the broken chain wrapped round the rear hub and locked the back wheel up.
It's a one-piece jobby - when it goes, it goes. Also, the whole drive chain's so worn I take it as read that when I do push the button it'll be a question of changing the whole lot - chainset, chain & sprocket.Just to be clear - you just need to change the chain ring, not the chainset.
And put his swee'peas at risk.Prob the main danger is the chain starts to slip under load and you plant your face onto your bars or delicate parts onto the crossbar!
