No. But it depends on the dog and the circumstances at the time.Is it really 'irresponsible' to let your dog wander about on a shared path?
I've mentioned this on the commuting thread but are planners just idiots? There are two rec grounds on my commute, both with dogs, and the geniuses decided that the cycle part of the path should be right next to the grass and the pedestrian bit the other side furthest from the greenery so you get kids, dogs and adults constantly crossing your path as you cycle through.
Awww, bless ....I've mentioned this on the commuting thread but are planners just idiots? There are two rec grounds on my commute, both with dogs, and the geniuses decided that the cycle part of the path should be right next to the grass and the pedestrian bit the other side furthest from the greenery so you get kids, dogs and adults constantly crossing your path as you cycle through.
Sounds like the one round the corner from me in Sutton...it's not an issue...you just have to take careI've mentioned this on the commuting thread but are planners just idiots? There are two rec grounds on my commute, both with dogs, and the geniuses decided that the cycle part of the path should be right next to the grass and the pedestrian bit the other side furthest from the greenery so you get kids, dogs and adults constantly crossing your path as you cycle through.
Sounds like the one round the corner from me in Sutton...it's not an issue...you just have to take care![]()
Not talking about when you first enter the park on the Sutton side, I just think for most of the path it would be more sensible to have them swapped as it seems more people use the grass and the play area than the skate park. The other one iI go through is up by Cheam and that has absolutely nothing on the side of the ped path until the turning for the supermarket. The entire rec ground is to the right of the cycle path. That definitely should be the other way round.Hmm no that one I don't think so as you couldn't have the cyclepath running by the other facilities. It makes sense to have the big area for peds
Nonsuch along the A232...yeah it was that cycle path where I came a major cropper back in 2009 while thinking I could go off the path and avoid a schoolgirl, too fast, lip too deep, went flying and my knee is knackered for goodNot talking about when you first enter the park on the Sutton side, I just think for most of the path it would be more sensible to have them swapped as it seems more people use the grass and the play area than the skate park. The other one iI go through is up by Cheam and that has absolutely nothing on the side of the ped path until the turning for the supermarket. The entire rec ground is to the right of the cycle path. That definitely should be the other way round.
ouchNonsuch along the A232...yeah it was that cycle path where I came a major cropper back in 2009 while thinking I could go off the path and avoid a schoolgirl, too fast, lip too deep, went flying and my knee is knackered for good![]()
