Zippy
- Camborne, Cornwall
I have a problem in the drive chain somewhere I think.
· Indexing ok both ends of the block, no play in the rear wheel or bottom bracket.
· B tensioning screw is correct – jockey not riding on the chain.
· Jockey wheels seem to be keeping the tension ok before the block although they are quite worn (plastic).
· Chain and block replaced at the same time and the problem seemed to get worse soon after the change.
· No play in the bottom bracket or pedal cranks. Both spin ok when not loaded.
· No falls on this derailleur, nothing twisted that I know of.
It feels like something is crossed slightly in the drive chain, like the chain is riding off angle and then correcting itself. When it does it sounds like the chain is twisting slightly and puts a small vibration up through the frame. Sounds like the chain is about to switch gears under pressure, but it doesn’t and indexing is correctly adjusted.
Any ideas? I think – go to a good cycle mechanic!
