I can sympathise with car drivers, on an unlit road, dimmed lights don't give you a view of anything much
Unfortunately some of them do, and they end up posting nonsense on this forum.Some people should stay in more.![]()
I'm with Matthew on this one... just dip yer fecking headlights you ignorant morons. not doing so is all part of the 'cyclists don't really matter' mentality of some motorists.
The lowest dipped beam setting should be high enough that you can travel at about 40mph on a completely unlit road, User269 pointed this out earlier. With centre aimed headlights you should be seeing further up the road.on an unlit road? The cars I have driven that where made in the past 10 years I wouldn't be comfortable doing that.
I have a bit of OCD when it comes to shoulder checking. I am always doing it. Even when the road is clear behind. I just like to know what is behind me.I don't do shoulder checks in daylight on rural roads and am even less likely to do them at night when I can see from my shadow in front of me just how much clearance I'm going to get from the overtaking vehicle. If the road is single track I would press on to the next passing place on becoming aware of a vehicle behind me, there is little to be gained from shoulder checking.
I also agree with Matthew. Australian motorists do this all the time: they seem to use the high beam as the default, instead of using low beam and only switching to high when absolutely necessary.I'm with Matthew on this one... just dip yer fecking headlights you ignorant morons. not doing so is all part of the 'cyclists don't really matter' mentality of some motorists.
Because when wearing glasses, it causes glare. And if I wanted to turn right, full lights make it difficult to determine how fast the car is approaching. It also blinds you a little when you shoulder check.
