Drops or flats
vbc
Bristol
Out of interest, I'd like peoples views on the suitability & comfort of drop bars versus straight bars for touring.
I plan to do a JOGLE in the future (might have to delay a year due to accident) and am wondering if I would be better off getting a dedicated flat bar bike with 700c wheels and disc brakes made (Argus & Robin Mather are nearby) or would I be OK using my Planet-X Kaffenback?
Opinions would be appreciated.
Bigtallfatbloke
I'm no expert but I reckon it's just whatever is most comfy for you. Touring you tend to spend a lot of time sitting more upright. I have drops...and I love'em....plenty comfortable and I have three positions to choose from instead of one.
alfablue
I prefer drops, I use them mainly holding the hoods, but I find the wrist much more comfy oriented vertically; on flats they always seem a bit twisted too far inwards to be comfy
Leilei
I prefer drops, there are at least three hand positions and they are all natural and comfortable, going down onto the drops into the wind is also very convenient.
asterix
Comrade Member
Limoges or York
Drops are best for any sort of distance. Being able to change position is a big advantage esp. as Leilei says when going into a headwind.
campagman
at home
I used to tour on drops and yes my hands would be moving pretty frequently to find a comfortable position. I then started to use my old MTB for touring and have not had a problem with the flat bars. Bar ends are a must though, they make climbing so much easier and also offer an alternative position.
JC4LAB
Drops..but how expensive it is to get one nowadays.!
Cathryn
I have drops and like them, but toured with flats for a a couple of trips and never had any issues. Not sure I'm entirely believing the received wisdom that drops are best for touring.
asterix
Comrade Member
Limoges or York
Drops make a big difference if you want to make progress into a headwind. My tourer has them, although it is has mtb wheels and clearances. Recently I encountered two mtb tourers with flat bars and for most of the morning we were doing much the same speed. Around mid-day they were about 200 metres ahead, and hit the headwind just before a summit. Being able to lose a bit of wind resistance on the drops I left them behind.
Around 4pm I was having a break in the town square and when they suddenly appeared and very kindly returned one of my drying socks which had fallen off the pannier.:biggrin: So, if no drops, only one sock:sad:
fks
The Kaffenback should be fine to do the trip. Just make sure you have a wide range of gears and wide tyres.
I use flats with barends, Ihave also used drops(XC USA and LEJOG) but I prefer flats as I feel that I have better braking control.
bonj2
Flats with barends are better.
Most of the people with drops (well, all the ones I see) never actually use the drops, so they're pointless. If you watched that film of Jane Tomlinson's (RIP) tour across america, never uses the drops once.
People will say 'ah but you can use the hoods', although having bar ends gives you the ideal version of the 'hoods' position, and the position is more adjustable.
Drops are uncomfortable because your body's hunched over too much, so it's uncomfortable on your torso and abdomen - consequently people only use it when they have to, i.e. for maximum aerodynamics when racing.
U
User482
Completely disagree. I've toured with flat bars/ ends, and with drops. I much prefer drops - the hoods position is very comfortable and allows you to access gears and brakes without moving your hands. I use ITM "Marathon" bars, which have extra flex built in, and have a nice anatomic shape. Didn't have any discomfort in my upper body or arms all the way to JOG. What I did do though, was to raise the stem (advantage of still using a quill stem) and to rotate the bars slightly back so the hoods were higher.
