Dyno hub on a trice
Tilley
Bristol
I quite like the idea of having a dynohub drum brake combination in one of the front wheels of my Trice QNT.
I gather that the weight of the dynohub may have an adverse affect on the steering geometry due to the increased weight on one side. However my most intriguing question is how do you cable it. given that you don't have a fork leg to run the cable up and the dynohub connections are on the outside face of the wheel?
I would guess that someone on here has the answer and photos would be very useful.
Scoosh
Velocouchiste
Edinburgh
Would the dynohub work on the rear wheel? Might add some electric string but could be simpler …
Tilley
Tilley
Bristol
I don't believe you can get a dynohub and rear cassette combination and as I also have a disc park brake on the rear the whole combination could get a bit costly.
There used to be an issue with a combined drum brake combination and overheating
I don't know if modern versions have the same issue
