Egg boilers
Dadam
SW Leeds
Anybody used these kitchen gadgets that use steam to boil one or more eggs? Have you got it to cook to perfection?
I'm partial to an occasional dippy egg for breakfast, with toast soldiers of course. I like my egg to be solid set white but runny yolk.
Nobody else in the family is bothered though, so I had to boil a whole pan of water for one egg which is wasteful of energy, and also of my time in a morning.
They work by adding a measured quantity of water depending on number of eggs and desired state (soft, medium, hard). The eggs steam until the water runs out at which point a thermoswitch detects the temperature of the heating plate and switches off. This means a very small quantity of water 50-70ml or so cooks an egg, so the energy used is a fraction* of boiling a saucepan.
*I could measure the quantities and hence calculate the energy used for both methods but I just can't be arsed right now. It's got to be less than 10%, and the eggs cook in half the time.
Browsing round Asda I took a punt on their own brand egg cooker for the princely sum of £8. It'll do up to 7 eggs, but I've only tried it with one. It's not bad, it does do the job, but has a couple of drawbacks.
It doesn't go ping when it switches off, so you've got to be hanging around the kitchen waiting for it. I can deal with that.
I've been experimenting with the exact amount of water (it's supplied with a little measuring cup), and every time eggs from this device usually end up with a snotty white at the top and the yolk at the bottom being hard, so there's obviously a temperature gradient. Instructions tell you to put the egg in upside down (rounder end up) so this suggests the steam collecting toward the top make it hotter. I've tried inverting the egg halfway through but this hasn't worked. What I could try next is cooking the egg in one of the outer holes instead of the middle one. Maybe the flow of steam is more consistent there, dunno.
Glasgow
Ahem ... just get a small pot?
I've got one that fits 2 eggs max.
Surely the energy and time using a small pot to boil one egg is the same as using the Asda 7 egg gadget.
You already know how long your preference takes, just tell Alexa to set a timer ^_^
Dadam
SW Leeds
I don't know, that crossed my mind but if it's small enough to only take 2 eggs max, it's not going to heat efficiently as it's not going to cover the hotplate, at least in my kitchen. How long does it take to boil?
Glasgow
I see, you have a different hob than mine, I've got a gas hob, never could get the hang of electric ones.
I don't actually eat soft boiled eggs, I use them hard boiled on salads.
My small pot takes about 5 minutes to come to the boil, if you use hot water from the tap maybe 3 minutes.
Next time I use it I'll take a picture of it for you and I'll time how long it takes to boil.
Shortfall
How much energy do you think the occasional dippy egg is going to use? You're over thinking this. Just use a small pan and minimal water, the eggs don't have to be completely submerged. FWIW I cook my room temperature large eggs for 5 minutes in boiling water for a firm white and soft yolks.
I sort of got poached eggs done 'ok' during lock down, but I'd like a good reliable way to do one camping. Frying eggs is very dependant on the quality of the frying pan. I never get it quite right, but the eggs will do.
Tips folks ?
Dave7
Cheshire
Not quite the answer you want but I have just got a similar gizmo but for poached egg.
My micro power is 900 and if I turn that down to 70% and do it for 45 seconds it's perfect........you will have to experiment to get it right for your wishes.
As @CentralCommuter says an airfrier does nice "boiled eggs" (with no water) but it takes 8 mins(ish).
Dadam
SW Leeds
Yes a ceramic one, so easy to clean. I like the instant heat of gas but wouldn't go back to it. The cleaning and having to have it serviced by a professional, no thanks!
Well it may not be a big proportion of the electric bill, a few pence, but why use more than you need? My smallest pan needs about 700ml to nearly cover an egg. The egg boiler takes a tenth of the water, so a tenth of the energy.
The bigger pain is the time getting it to the boil to start with. The egg boiler takes about 6 minutes start to finish.
