rogerzilla
Have a look at the regs. 6mm cable can be ok for up to 9.5kW (which is still fairly weedy) if short and surface-mounted - it's all about heat. As fossyant says, duration is also a factor and most are rated for 15 minutes' use per hour, or similar.
Electric showers are fairly horrid things, though, never being quite powerful enough, expensive to run, and short-lived in hard water areas because the small heater tank can't be descaled. If you have a pressurised hot water system from a combi or an unvented cylinder, try to use that instead. Even gravity showers can be good if plumbed correctly, with all formed bends in the pipework.
