LukeEngineering
So what I've made is a bike light with an LDR, tilt switch and Rocker switch.
The lights turn on when the light level drops below a certain amount.
The tilt switch then decides which colour lights will be on (red or white) (depicted in images below)
If positioned on the back then Red Lights will show.
If on the front white lights will show
If used in daylight then the Rocker switch will just turn the white lights on and off or if at night it will turn the lights off.
I'd like your opinions on the following:
-Size
-Design/appearance
-how marketable it is (whether you'd be prepared to buy one and for what price)
-Simplicity to use
-how much you'd pay for one
-Size
-Design/appearance
-Simplicity to use
