I appreciate that this a bit techie for a cycling forum but it seemed daft to me to create a login on a tech forum only to ask one question... besides, there are some clever techie types on here
I've got a Netgear managed switch (a fancy hub in effect) that has a 'cable tester' function. I've never really paid much attention to it in honesty. Anyways, it reports a 'cable mismatch' on one of the cables; the main cat5e cable from the router - so potentially affecting all the devices plugged into the switch. The help tells me it's an "impedance mismatch" (first I've ever heard of such a thing in honesty) and I replaced the cable as suggested but I get the same error having tried a few cables.
Web searching tells me what the error is and whilst I can understand the issue, I'm a little lost to know whether it's actually a problem in practice, as there doesn't seem to be anything untoward happening on any of the devices connected to the switch.
The cable from the router to the switch is maybe 20m long, from inside the house to my work space in a detached building, mainly underground and through a couple of stone walls (so not possible to replace!) with 2 rj45 sockets either end. Is it possible there is a problem with one or other of the sockets? A simple cable tester reports no problem.
I'm inclined to ignore the error. Maybe the Netgear diags are a little simplistic/not to be trusted, I don't know.
