Falcon Olympic ~1966 - Fix or Full Refurb?
Ian48
Member
Cheltenham, UK
Hi.
I have a Falcon Olympic that I bought in Rochdale around 1966 and rode in my teens, 20's and occasionally since.
Sadly it's original 'flamboyant' gold (or bronze?) began rusting and to preserve it I stripped and repainted it.
That lost its decals and beauty - but it has very effectively preserved the frame! Obviously not the steel rear wheel or rubber Weinmann lever hoods.
Mostly it's still original, except for the repaint, the front wheel, tyres, brake blocks and I think I changed a rear sprocket. The rear wheel now needs replacing too.
I'd like to start using it again - though at my age (78), just locally around Cheltenham, which is a bit hilly - but they've just constructed a lovely new cycleway alongside the A435, so someone ought to use it! ;~)
My challenge is, should I
a) Just do a quick refurb : ie. clean-up, new rear wheel, tyre(s), brake blocks, and any other essentials, OR
b) Get a full professional restore back to near original (colour, decals, etc.) plus some improvements* (wheels, tyres, brakes?, cranks?, gear set?).
* I always found the brakes a bit lacking as their mechanical design allows deflection, so the pads rock backwards on braking.​
Also, the original steel rims obviously tend to rust.​
Web searches suggest that after a full restore it might be worth ~£450 (if lucky) and that a full professional restore could cost ~£1,000 ish.
? Qns for those of you that have done such a full restore:
  1. Does that end value and full refurb cost look about right?
  2. Any suggestions re who to entrust the work to? So far I've noted Argos Racing Cycles (Bristol) and Ellis Briggs Cycles (Shipley).
Any other thoughts? Eg. re improving the wheels+tyres, cranks, gear set, braking, or other worthy tasks?
Punkawallah
I think the expression goes ‘it’s only original once’ - so the re-paint means you can go hog wild. Be aware that whatever you spend you will not see back if you sell.
I’d be inclined to take some time, and decide how much pleasure you’d get riding it ‘as new’, as opposed to riding a modernised version. My Galaxy has been upgraded and had the frame & forks restored by a local builder, and is a pleasure to ride for me every time it goes out.
The good news is that 27” chrome rims are still available, so I assume a wheel is. Ellis-Briggs is well spoken of where I am.
Good luck!
