fitting a bar bag
GrumpyGregry
Here for rides.
on my sora equipped tourer I just push the cables out of the way, so they go down the sides of, and then under, the bar bag when attaching my bar bag with a rixen & kaul klickfix bracket. but I have very wide drop bars as I'm a big bloke.
contrary to what various doom-mongers have told me, it has zero effect, absolutely none whatsoever, on the shifting ime
Spinney
Bimbleur extraordinaire
Back up north
Why was my post removed?
If it was because I had linked to a bar bag that fitted drops + shifters, I wasn't advertising, and lot of other people include links to products.
GrumpyGregry
Here for rides.
No idea. Suggest you draw admin's attention to your post
tyred
Ireland
There are duplicate posts on this subject and you've posted in the other one originally.
potsy
Rambler
My Armchair
Stop being so paranoid Spinney,your post is still there but there are 2 identical threads.
You're on the other one.
G
Graham1
thank you, i have a bag that i used on my flat bar bike. i have wide bars Greg so i will give your way a try, just thought there might be some way of moving or extending the cables.
GrumpyGregry
Here for rides.
I put one of them on to get the rack bag to clear something mounted on the bars. Made no difference to clearing the gear cables with Sora.
PpPete
Chandler's Ford
Like others I've run Shimano shifters with a slight bend in the cable to accomodate a bar bag (on R&K mount)
Just a bit of a faff getting bag on & off sometimes, and that combined with numb hands from riding the Shimano hoods led me to try Campag Ergo shifters .... solves the cable problem at least.
gwhite
If you don't want to use the extender then it's possible to use V brake noodles encasing the cables at the hoods to bend the cables away from the bar space.
