beatlejuice
Gently does it...
- Mid Hampshire
Last October I brought a Cytronex ebike conversion kit for my Decathlon Network 700. The choice of this company because it was local. I live and work in Winchester. Being a hilly place the conversion would mean I would be more likely to use a bike for work rather than drive. My shifts are often 12.5 hrs long and peddling up a nasty steep hill on a wet cold night after work isn’t particularly pleasant has I am approaching old fart status, being 60+ !
An eBike conversion kit can be brought for a lot less than the Cytronex item. My research lead me to believe that I would need a sensor detecting motion of the chain/belt If I want to meet Pedelec legal Spec. Typically it would on the crank. There is very little clearance between the crank arm and thee bottom bracket about 2mm at the most. There wouldn’t enough clearance. The Cytronex kit has a sensor that detects motion of the rear sprocket. It is mounted on the rear drive side stay and points at rear sprocket. The tip has be be 1 to 4mm away from it. The battery has a limited capacity but since I didn’t intend to go far that wasn’t an issue for me.
The basic kit cost about £1000, I added lights which work well but added another £200. This is way more than other kits of a similar nature. If you want them to fit it then that another £150 so I myself.
I had issues getting the sensor mounted correctly so asked Cytronix to have a look. Then I got the tough love approach to customer care. They sent me a PDF containing instructions but no just popping in the shop to have a look. You book an appointment and get charged @ £30.00 per half hour! I found the thought of being charged at this rate by a bike shop did concentrate my mind somewhat. I got the sensor fixed and all is currently well.
In conclusion was it worth it? I am doubtful, I guess the sensor isn’t unique to Cytronex and could fitted to a standard ebike conversation kit. The total cost of the various bits I have fitted to this bike plus the original cost works out to an amount which could buy an ebike of a decent specification.
