Flashing cycle lights???
garrilla
Liverpool
Davidc said:
Warning - Seriously and dangerously outdated information - now completely wrong.
The full legal requirement is here
http://www.ctc.org.uk/DesktopDefault.aspx?TabID=4071
Great. An outdated goverment website. Who'da thunk it?
siadwell
Surrey
To be fair, the amendments amend the existing regs, and the link you followed is a direct one to that document, so the website isn't out of date. They just make it very difficult to find the info you need.
The Highway Code has this rule, but a little more detail or direct links wouldn't go amis.
60
At night your cycle MUST have white front and red rear lights lit. It MUST also be fitted with a red rear reflector (and amber pedal reflectors, if manufactured after 1/10/85). White front reflectors and spoke reflectors will also help you to be seen. Flashing lights are permitted but it is recommended that cyclists who are riding in areas without street lighting use a steady front lamp.
[Law RVLR regs 13, 18 & 24)]
EDIT: Actually, you are quite right, as the HC website has a direct link to the outdated regs with respect to this RVLR, and no mention of the amendments. I only knew because I'd read it on the CTC website.
garrilla
Liverpool
BentMikey said:
You've missed something Garilla, which makes your point wrong.
I wasn't making a point, I was merely relaying what the regulations said. Anyway, I'm really grateful that you were willing to point out the error instead of scoring points. ;)
Davidc
Somerset UK
Not your fault G. Typically for government what they've done is to ammend a set of regs with a set of ammendments which in part make the original illegal!
If Whitehall had a sigle brain cell somewhere in its length they'd simply publish a new and correct set of regulations when there's a significant change in the content.
(Don't believe it's just transport that suffers from this!)
PK99
SW19
simongrant said:
Hi all,
This may just be me and my eye's but when there is another cyclist oncoming with front light flashing i find it quite difficult to gauge there position in particular distance and it seems the brighter the light the harder it is.
Anyone else find this or should i have gone to specsavers??;):laugh:
Simon
I agree.
A constant light indicates position and direction, a flashing light shows position but not direction until the next flash.
The worst one i saw was recently in Phlegm.
VERY RAPID Flash-flash-flash-flash-flash......LONG PAUSE.
Where has the damn thing gone?
Repeat.
Davidc
Somerset UK
PK99 said:
I agree.
Repeat.
And that is quite clearly not a legal light under any of the rules!
Davidc
Somerset UK
Trouble is with all this that if there's an accident and you're outside the legal niceities then some smart ars'd barrister on the other side will try to claim you were responsible for it.
BentMikey
Rider of Seolferwulf
South London
Why would you assume I was trying to score points? My reason for not posting the direct link to flashing light info is that I hoped it would cause you to think and remember the issue.
Edinburgh
siadwell said:
60
How the feck to you fit reflectors to uncaged SPD's?
siadwell
Surrey
Ah, you have discovered one of the anomalies in the regs that did not get changed, despite lobbying from the CTC. This also applies to 'bents.
