Foot location on pedal
travellingwest
Forgive me if this is in the wrong forum.
As a kid and even right up until the last bike I owned, about 17 years ago, I always rode with the middle of my foot on the pedal. This time, having been reading in certain circles that it should be the ball of the foot, I've been doing that.
Two problems: one, I cannot keep my heel down (I had this problem horse riding too!); and two, maybe as a result of one but not sure, I was suffering significant anterior knee pain at the end of a ride.
I did some research on t'internet last night and it seems that actually, the ball of the foot isn't necessarily the best position on the pedals; it is good for a sprint but not for the long term. It seems that it can cause other physical issues. So, on my pre-dawn, pre-rainfall and pre-work ride this morning using the middle of my foot on the pedals, result = no knee pain. Also, no loss of power, felt very comfortable and natural.
So I wondered, how many of you pedal with ball of foot or middle foot?
Ajax Bay
East Devon
I set my (spd-SL) cleats back as far as they will go so the pedal axle is a small distance back from the ball - towards your 'middle'. If you've found a position which is better, for you, what's not to like?
All my riding is longer distance (>60 miles), except riding to the pub. My road shoes have pretty stiff soles.
"The recommended foot position over the pedal spindle is almost universally acknowledged as the ball of the foot. The ball is one of the three "rockers" of the foot, along with the heel and big toe. It is at the end of the body's only first-class lever, and is ideally placed to be both a powerful and stable point to apply pressure to the pedal. The "ball" could be regarded as quite a large area though, so we need to be a little more precise in defining exactly what we mean by it.
"As a rule, there is often little downside to the cleats being too far back. Being forwards encourages a 'toe down' posture and can give toe numbness and 'Hotfoot'.
"The diagram (from "Understanding Joints" by Bernard Kingston) shows the many bones of the foot. The "ball" is regarded as the area at the distal end of the five metatarsal bones. For cycling we need to use a horizontal line, so choose a best fit through the first four. In the diagram shown, the horizontal alignment of the first three is very good but in the real world this is not always the case, the second often being the longest. The position of the first metatarsal is fairly easy, being the bony bump on the side of the foot by the big toe. The rest often reveal themselves when the toes are flexed."
https://www.bikedynamics.co.uk/fit01.htm
I agree, I've always tried to position the widest part of my foot over the pedal spindle. It helps to ride often with cleats (or, when I started, toe clips).
But different maybe if you're getting pain.
Widnes
I ride however it feels right
I have been riding like that since I was about 11 and I ain;t changing now!
having said why - the MTB flat pedals the LBS put on for me afew years ago have allowed me to cycle with the balls of my feet more easily and I do that sometimes
but if I do the seat feel a rad too low!
esoxlucius
I think it's quite common for cyclists to be constantly curious how other cyclists do things. And probably even more common that when they discover that other cyclists do things differently, then that means you must be doing it wrong!
We're all different, you do what's right for you.
All uphill
Still rolling along
Somerset
I use flats and use the ball of my foot. I vaguely remember a grown up telling me that I'd wreck my feet if I pedalled on the insteps.
I wonder if changing foot position might require a small change to saddle height?
It's a general starting point (ball over axel). I was getting hot foot with a particular pair of shoes, didn't check hard enough, but found I'd fitted them with the cleat too far forward to what I was used to. I've always ridden with ball over axel, but there is no right/wrong, other than it's more difficult if you aren't clipped in to do the ball over axel.
Flat pedals and middle of ball for me. One of the things I like about flat pedals is that you can move around if you fancy it.…it might not give optimum performance but sometimes it feels good.
roley poley
leeds
Never rode cleats but did toe straps to keep my feet where they, allegedly ,should be but now prefer flat pedals for the freedom of movement and release as a utility cyclist ..do what feels best for you for comfort and fit... experiment ...we aren't all in the tour de france :smile:
Windle
Burnthouses
The knee pain maybe just due to the change of pedal stroke position / amount of leg extension. I've noticed my knees getting a bit achy when I've been on the MTB and the seat post has slipped down without me noticing.
When I started riding seriously I initially rode the way I did as kid, with the middle of my foot on pedal. Then, when I got a bit more serious and first tried toe clips & straps the position felt really odd, as if my foot wasn't far enough over the pedal platform. I persevered and soon got used to it though, and have ridden with ball of foot over axle ever since.
I think the racing mindset is ball of foot for maximum power transmission, but I've always reckoned that surely the most efficient position is ball of foot as when you think about it, that's the way our feet land when running, landing then pushing off again ~ it's as if our feet are designed / have evolved to be used that way. The middle of the foot doesn't really seem to as suitable for load bearing.
Punkawallah
A wise man once said, ‘if it hurts when you do that, don’t do that’.
My feet dance like Russian ballerinas over the pedals, sometimes floating like dandelion seeds, sometimes glued like a bike sticker you really want to come off. But I use flats on the tourer and hack, and (loose) pedal straps on a racer, so what do I know? My concession to ‘science’ is to remind myself that the outside of my feet should not be hanging off the outside of the pedal, and point my feet inwards - which I suppose is why I never made the Bolshoi.
