Freewheel Question
Psyclist
Northamptonshire
So I have a 27" wheeled bike which I want to make single speed, but retro stuff is new to me as I'm used to modern :wacko:
I'm getting a new wheelset, but all 27" wheels are freewheel.
Would the below cog work?
http://www.ebay.co.uk/itm/BMX-MOUNT...sure_cycling_bikeparts_SR&hash=item2c624f5336
Any help will be appreciated.
Thanks.
EDIT: Would it run straight away if I screw on the cog and be aligned okay, or will I have to re-dish and re-space the wheel?
PpPete
Chandler's Ford
That's for a 1/8" chain.... may not be compatible with the rest of what you are putting on the bike?
RecordAceFromNew
Swinging Member
West London
While you could buy a 3/32" single speed freewheel to address the existing chain compatibility issue or buy a 1/8" chain to replace the existing chain, it is unlikely that you will have a good chainline without redishing a multispeed rear wheel unless the chainring (position) you are planning to use is very close to the BB. This will help you figure it out.
