Newbie question
Bigmoss
Member
Hey guys,
I just swapped the cartridge bearings on my rear Campy Mirage hub and cleaned everything up. Now I'm putting it back together, but I forgot how much grease goes on the sleeve. Should I pack it full or just do a light coat?
Thanks
Ajax Bay
East Devon
sleeve?
and :welcome:
gbb
Peterborough
if its similar to Fulcrum wheels i had, there's a spacer sleeve internally between the two bearings. theoretically it should be a sealed area in there, any moisture / much would have to get past the outer seals then the bearing shields so i didnt generally bother putting anything on mine. Never had a problem in there
