Which freewheel remover do I use to remove this freewheel ?
midlife Guru 21 Apr 2015 #2 Top That looks like an early freehub, the smallest cog being screwed on retaining the others which are splined. Shaun
raleighnut Legendary Member Location On 3 Wheels 21 Apr 2015 #3 Top ^^^^+1 2nd one of them to come up recently.
midlife Guru 21 Apr 2015 #4 Top I've got a set of very nice wheels in the garage without the cogs and they are a nightmare to find as I think they are uniglide.. Rose in Germany Shaun
Tim Hall Guest Location Crawley 21 Apr 2015 #5 Top midlife said: That looks like an early freehub, the smallest cog being screwed on retaining the others which are splined. Shaun Click to expand... The picture looks like the OP has got the top sprocket off. If so, the rest should just pull off.
OP Wester Über Member 22 Apr 2015 Thread Starter #6 Top midlife said: That looks like an early freehub, the smallest cog being screwed on retaining the others which are splined. Shaun Click to expand... So i do not need a freewheel remover just unscrew the smallest cog anti clockwise and the bigger cogs will slide off no problem
midlife Guru 22 Apr 2015 #7 Top Not my area of expertise but your hub probably looks like this Two chainwhips to unscrew the smallest cog anticlockwise which I think is still there? Shaun
