Friction bar-end shifters?
SuperGalactian
What’s your experience with these? Is it easy to diddle the chain into true alignment when you shift sprocket/gear, and does any inaccuracy in that regard cause noticeably faster wear of components? I’m trying to keep my upgrading options open whilst retaining bar-end shifters.
Webbo2
What’s your experience with these? Is it easy to get the
Use to use them years ago when riding cyclocross my recollection is they don’t hold a candle to brifters.
All uphill
Still rolling along
Somerset
I love the friction bar-end shifters on my Temple bike. They must be 40 years old and work perfectly . I'll be putting friction thumb shifters on my Spa soon.
For me the advantages are that they encourage a relaxed riding style, they don't go out of adjustment and they are cheap and simple.
I currently have 3x8sp, may have to replace this year with 9sp, and by the time that chain wears out it’s possible we’ll be forced to use 10sp.
(With the exception of my uncle's old Clockwork) all my derailleur bikes are 9 speed. Decent 9spd parts are still widely available. And very cheap compared to equivalents with higher sprocket counts. You'll not be forced to use 10 speed any time soon.
S
SuperGalactian
I find that hard to believe, given the difficulty of getting 8-sp components now. On another bike, I'm still keep a freewheel set-up going, but the quality of available freewheels is dire.
nogoodnamesleft
I used to have Microshift 10-speed bar end shifters on my bent (tadpole).
The rear 10 was set to indexed mode, the front tripple friction.
The first rear indexed worked well (free to move and once set held it's indexing, no need for continual adjustment). But the pivot bolt gradually worked lose and going over a bump (eg level crossing) would suddenly self-shift down to small rear cog. I ended up riding with an allen key and every few rides I'd be tightening the bolt (a very easy procedure to set correctly). In the end got the shifter replaced under warranty and replacement fine.
Front triple friction held its setting fine but also used a lot less.
For other reasone I upgraded rear to Rohloff (switching to Rohloff twist shifter) but kept front fristion level but now on a double. Front still fine but normally only used a few times on a ride and in Flatlandia most riding on the larger front chainwheel.
Overall I regard them as OK, they work (subject to what must have been a faulty one).
I never considered them on my upright as touring I'd worry about them being more vulnerable when bike resting against all sorts of less secure things, laying on campsite ground overnight, etc. But I have no evidence they wouldn't take this, just speculation and I like my STIs anyway.
T4tomo
I have an indexed 10spd microshift bar end on my gravel bike, works seamlessly
Also have the old ratchet friction shifters, SunTour bar cons, on my old 80's holdsworth -which are a similar joy to use.
