Have the aforementioned on my 18 mth old bike. Anyone know what is required to give the crank a bit of a tighten up ? The locking bolt on the non-drive side is 10mm and I have a 10mm Allen key. There is also some sort of lock-ring around the locking bolt with 6 small holes around it. Do I need to do anything with the lock-ring or can I stick the Allen key in and give it a tighten ? If that`s all required, what direction to tighten ... I would assume clockwise. If it is not quite so straight-forward, I assume a special tool needed for lockring ?????
What you call the lockring is a self extracting bolt through which the main Allen keyed 10mm bolt runs. A little complex to explain, easier to see when you get apart, but the self-extractor screws into the crank and has a shoulder so that when you undo the 10mm bolts it backs out against the shoulder, effectively 'pulling' the crank off the spindle with it.
Anyway, it might be worth getting a bike shop to look at this if you cannot achieve good tension/tightness just by doing up the 10mm bolt a bit. Play in cranksets such as these can be because the holding bolt (the 10mm) is loose, or because there's room measured across the bearing faces (they use a wave washer to 'pack' out the slack a bit but it's vulnerable to wearing out). Or movement might come from the bottom bracket cups being loose, or combination of the above. Yours is likely to be a MegaExo BB set up, I'd say? Do you have a competent LBS who won't just say "spend a $$$ and replace it" but can actually diagnose and rectify?
First, see if you can tighten it a bit. Beware, some of those alloy 10mm bolts were made of cheese; ensure you get the Allen Key fully recessed and take it easy. The first one I had chewed out; I took it too the LBS who said "oh yeah, FSA gave everyone spare bolt kits 'cause it happens all the time" and replaced it for me. I think that has since been rectified, but its a good idea to make sure the tool is fully engaged regardless.
So, tighten clockwise (from left hand side facing bike), no special tool needed for self extractor.
Cheers
