FSA saga
Discussion in 'Bicycle Mechanics and Repairs' started by Matthew Fox, 10 Mar 2017.
Tags:
  1. Matthew Fox
    Matthew Fox Active Member
    Hello All,
    I recently replaced my FSA BB-4000 (19mm) bottom bracket.
    I am now looking to replace my cranks, however I have ran in a problem due to the FSA size being 19mm. I was looking at upgrading my FSA cranks to Shimano however not sure what is compatible. There has been quite a few threads I have seen but not been able to get my head around what is compatible with the FSA bottom bracket. What cranks can I get?
    If there isn't a compatible cranks can I replace the BB with a shimano hollowtech II?
    Please could someone help explain?
  2. S-Express
    S-Express Guest
    You can replace the chainset/BB with any other system compatible with a 68mm BSA BB shell.
    Matthew Fox likes this.
  3. martint235
    martint235 Dog on a bike
    Welling
    Yes you can is the answer. I had a FSA crank on my Ti when I bought it. I was involved in a pile up which scuffed the lever hoods and made the FSA crank bend like plasticine. Switched straight away to Hollowtech II and a 105 crank with no issues at all.
  4. Ajax Bay
    Ajax Bay Veteran
    East Devon
    What @S-Express said. Just choose a bottom bracket which screws into your 68mm shell and a compatible chainset.
    Don't get hung up on Shimano cranks, at least not as an 'upgrade'.
    Jan Heine has written this on the subject of square taper.
    For more on bottom brackets, you may wish to read this post.
    Matthew Fox and S-Express like this.
  5. Hollowtech II cranks are 24 mm so you'll need a BB with a 24mm diameter hole. I believe your bike will be BSA standard, so any threaded Hollowtech II BB with English threads will work.
  6. OP
    Matthew Fox
    Thanks guys, i bought hollowtech II BB and cranks at 24mm diamter and this is working fine!
    gbb, Racing roadkill and Ajax Bay like this.
    Dismiss Notice
