andsaw
Just put new top bearing on my headset and the bearing cover (conical bit) that has a dust seal on the bottom, is not touching the frame like it was before, the gap between the cover and frame is a tad over 1mm, i know the previous bearing had a bigger outside angle face than the new bearing making the newer bearing sit higher up on on the frame face thus getting that gap.
The only difference between new and old is the tightening of the preload, the new one has a more pronounced its tight feel and you know when its adjusted enough, and the old had a more not so sure how tight you should go feel, is the new one ok and not to worry about it or should there be no gap and need say a 1mm shim, its on a cannondale supersix evo 105.
