fixedfixer
You'll see stones advertised for free on Gumtree when people want them taken away. Not much help as it doesn't sound like you have a 'tip trailer'. Maybe a couple of beers for help from a friend with a trailer?
...I'm not laying a membrane though. Nothing new grows on this blighted soil anyway.
Yes. Go for a flint in 20/40mm flavour for the reasons above, but also any sort of 'pea' gravel will make ideal cat litter as @User13710 says.
All membranes do is delay most of the inevitable weeding a few years (if you're lucky and have picked a good one). Even with completely evil builder's plastic sheet (as someone has used under part of my stone), some weeds will shoot astonishing distances horizontally to get through the overlap and find the sun (cypress spurge is one local curse that does it).Don't be tight and lazy! Lay a membrane and it'll save you in the long term. Trust me, I'm an African.
EDIT: In time the aggregated will mix with the soil and look awful. No half jobs. Darwin's earthworm and rock experiment demonstrates this perfectly.
Where different membranes have been used (now all long under the earth raised up by worms), the weeds merely come through at different rates now. Some mix of weeding, raking and chemical warfare (if you're into such things) will be needed forevermore IMO. Unless it needs to support heavy traffic (which will keep most weeds down) is it kinder than putting it to grass, thyme or similar? I'm not sure.
I'd put bark chip down rather than stones. I'd also take the laurel stump out myself rather than pay someone to do it.
And if you get the laurel stump out yourself, you have an honoury and instant job down here with me in Somerset.
I don't know. Probably not turf as then you'll have to mow it and pick grass out of the paving in the bottom of the shot! I guess I'm ranting and wondering if anyone has experience with something that works better than the expensive slate that I've used most recently. I guess I'd use slate for your problem patch, but I expect it'll last three years tops before you have to start weeding again.Are you suggesting turfing it or planting thyme instead?
