Anyone know how to tell if the unit is fully charged?
monkeylc Über Member Location leicester 1 Jan 2015 #1 Anyone know how to tell if the unit is fully charged?
TissoT Veteran Location The Home of British cycling 1 Jan 2015 #2 Either the Battery indicator in the top left/right screen will show full or it tells you to unplug ... its a while since I charged my 705 up
OP OP monkeylc Über Member Location leicester 1 Jan 2015 #4 I only got a cable to sync to pc with mine and when it's plugged in the screen just shows pic of unit and pc? No battery level?
HLaB Marie Attoinette Fan Location That little part of Scotland known as Peterborough 1 Jan 2015 #5 Switch the unit off and it should go to the charging page.
400bhp Guru 1 Jan 2015 #6 Hold down the on/off switch whilst plugged in. Also when you fire the unit up, the amount of battery level flashes up.
OP OP monkeylc Über Member Location leicester 1 Jan 2015 #7 Holding on/off doesn't do anything and I can't turn it off while synced to pc. Only way I can check battery is to unplug and turn unit on?
