wyre forest blues
I have recently purchased the garmin edge touring plus and I am having difficulty setting up the display for when I ride. On the display is the map and at the base of the display are two boxes. On the left I have the speed and on the right there is a direction indicator (eg SW ). However i want to replace this direction indicator with the distance travelled from the start.
I have tried to follow the manual and carried out the following instructions: set up menu (from spanner button): trip pages: map data fields: when navigating speed, distance.
However when I return to the home page and press the start /stop timer the bottom right box displays the direction indicator. I was hoping it would show the distance from my setting as described.
So I am not sure what I am doing wrong, or could it be the unit is faulty.
Thanks for and advice in advance.
Peter t (tightlines )
