Garmin lesson rant
Milzy
went for a short blast and knocked out 25 miles at 20mph. Returned home pressed pause on the edge but for some reason instead of holding in the lap reset button I pressed the power button. Ride lost. They shouldn't allow that to happen I'm fuming
Welsh wheels
Lycra king
South Wales
I know the feeling, I forgot to start Strava before a ride the other day! Totally sucks.
fullcycle
Birmingham
Would be good if they could apply a factory setting to the device to auto save any activity that you were only able to manually delete incase of scenarios like the above or a battery running flat
Glasgow
How come?
If I switch off without saving, on restart it says "ride-resume" or you can save it.
Edge 200, the basic one.
How come?
Mine is only an Edge 25 - is that even less basicier??
the_mikey
In general, powering down the Garmin (In my experience with a 200, 500 and 800) won't lose the ride data, it's ready to resume the ride when you power it up again, until you hold down the lap/reset button which ends that particular session and starts to record a new session.
It stores the data in whatever flash memory the unit has available (approximately 50Mb on a garmin edge 500), and the files are stored on the unit in the Activities folder, if you sort by date you may find your ride data is still there.
A more common problem is rider error, a rider will stop for a break and stop the timer, then fail to resume the timer when they continue their ride.
Tommy2
Harrogate
I've done a ride with my 910xt and switched it off when I switch it back on it prompts me to hold reset to save.
Not sure if I pressed pause or stop before switching off, maybe that makes a difference.
Shouldn't have done that, garmin devices are ok to power down without losing data
Even my 705 will let you power down, then turn on and continue - like at a lunch stop. Might be a glitch on the firmware, as the last few updates to the 705 made a real mess until they fixed it, and then brought out new machines. My 200 will also resume where you switched off ?
