Garmin Max Speed
Discussion in 'Bicycle Mechanics and Repairs' started by Gruff Eddie, 19 Jul 2012.
  1. Hi guys
    Anyone have any ideas why my max speed on my Garmin when in bike mode is so daft:
    http://connect.garmin.com/splits/200662306
    The average seems OK.
    Cheers peeps!
    PS - this is the first time I've used this 305 - newly refurbished, compliments of Garmin
  2. derrick
    derrick The Glue that binds us together.
    That's quick, when i use garmin the max speed is normally a bit out when compared to the cat eye, but nothing like your's.
  3. Kiwiavenger
    Kiwiavenger im a little tea pot
    Ive seen average speeds of 1230 mph through a tunnel where the GPS dropped out for a while. Could be that?
    On strava my max mph is only 3-4 mph over my cat eye
    Sent from my LT15i using Tapatalk 2
  4. OP
    Gruff Eddie
    Gruff Eddie Regular
    I wonder if it's just a couple of decimal places out?
  5. srw
    srw It's a bit more complicated than that...
    Interference from the overhead electricity lines on the railway? Take a look at the underlying data - it's a table of numbers which you should be able to access in a spreadsheet.
    Instantaneous max speed from our GPS is always dodgy - all you need is one record that is a few feet away from its actual position.
  6. OP
    Gruff Eddie
    Gruff Eddie Regular
  7. GrasB
    GrasB Veteran
    Nr Cambridge
    That's way to systematic to be a gps interruption. My guess is that when reading the .fit file something went wrong. As you said, a Garmin connect blip.
    Out of intrest do you have a wheel sensor ro do you just rely on the GPS location?
  8. OP
    Gruff Eddie
    Gruff Eddie Regular
    I just rely on the GPS location. I'm very new to the cycling lark, being an injured runner, so just using what I have for as much as possible.
  9. GrasB
    GrasB Veteran
    Nr Cambridge
    Opps I was thinking about the Edge 305 not the Forerunner 305. I wonder if things got a little funky because GC wasn't expecting that kind of speed?
    I will say my Edge 500 & 800 both register interesting max speeds when not using a wheel speed sensor.
    Dismiss Notice
