Garmin to Strava inconsistency?
monkeylc
leicester
Hi, just noticed that my garmin data when passed over to Strava is different?
My avg speed on garmin ride is 15.1 but then when the data gets sent to Strava it says 14.9. I know it's not a big difference but why?
T.M.H.N.E.T
Disc brakes - Stopping things since 1902
Northern Ireland
Algorithms.
monkeylc
monkeylc
leicester
I know that there will be a difference recording a ride with garmin and then Strava. What I mean is I record a ride using garmin and then when the data is synced with garmin connect it then syncs with Strava with different avg?
T.M.H.N.E.T
Northern Ireland
There is still a difference
"Garmin devices run a calculation during recording to total up your moving time, or the time you are not resting/stationary. This moving time is divided by total distance to get average speed. When your data is uploaded to Strava, a separate calculation is run based on your GPS data to determine moving time. This can be different than what your Garmin reports. If you see differences in Average Speed between Garmin and Strava, first check your stats for moving time and total distance as that should explain the differences. "
monkeylc
monkeylc
leicester
Makes sense now..... Cheers
bpsmith
I have just checked my rides from this year. Garmin App and Strava App match exactly. Average speed is literally to a 100th of a mph. I assume that it depends on the device being used?
