Garmin Varia Radar Rear Light Seat Stay Mount?
As per title. Has anyone managed to mount a Garmin Varia to a seat stay?
Please don’t bother mentioning saddle or seat post mounting options as the large Apidura saddle pack I carry negates these.
Thanks.
si_c
Wirral
Thanks.
Nope, I tried, the rubber strap is far too large to wrap around.
The way I found to do it will be to get a garmin mount with a go pro fitting and then use that to fit it to a seat stay, you can get go pro mounts that would attach easily enough. I haven't got around to trying that yet though beyond looking online to makes sure that I could find the necessary parts.
si_c
Wirral
If you find one let me know. I think Garmin are very remiss in providing such a small choice of mounts. I bodged one myself for the back of my rack
This is the downside of using the quarter turn mount on the rear. I think they could probably do with expanding the ecosystem a little, but to be honest I wouldn't swap the ease of removing/replacing the light for a wider range of mounts.
Milkfloat
An Peanut
Midlands
Would the radar even work properly if mounted significantly lower? A friend with a large saddlebag mounts his varia upside down so the light part of the unit pokes out with the body hidden behind the bag.
JhnBssll
Suffolk
I wonder if it was put too far down the seatstay whether the rear wheel might cause a radar shadow and prevent vehicles being seen in certain areas?
si_c
Wirral
Should be fine as it can track up to 5 vehicles at a time. If your back wheel was going to cause an occlusion then the car behind you certainly would.
alex_cycles
Oxfordshire
I rigged up a mount that sits on the back of the saddlebag, using a Garmin 1/4 turn mount and some custom laser cut parts.
It was designed to fit my road bike perfectly. It also works with my gravel bike but I do have to put the Varia on upside down.
The other option you may not have considered is putting it in a jersey pocket. As long as it's more or less vertical it still works fine (can be wedged in place with gilet/food etc.). Obviously the light won't be as bright, but the radar functionality works perfectly.
alex_cycles
Oxfordshire
Also have a mount fitted to the saddle bag https://www.cyclechat.net/threads/what-have-you-fettled-today.87079/post-6544525
On the subject of putting one on the rear jersey pocket would suggest fitting a mount to an appropriate sized piece of plastic card which would then hold it an appropriate height.
I was talking about "in the pocket" not "on the pocket". But that would certainly work :okay:. On the odd occasion when I use a bike that doesn't go with my saddle-bag I just wedge it with other items I have in my pockets and it works fine. It would be rare for me to do a long ride without my saddle bag though as it has all my support gear in.
