Gear select problem
Raging Squirrel
North West
I was out on my ride yesterday, and I was hearing a few creaks and noises. Anyway, after my ride, I was putting my bike away and notice a gear cable was a bit slack. So I went out on it again, and I cant select the big ring at the front. What have I done and how can I fix it?
Rob3rt
Man or Moose!
Manchester
Turn the barrel adjuster on the gear lever to increase cable tension.
sabian92
You can do smaller adjustments with the barrel adjuster. Just make sure you twist it the right way :biggrin: As I found out, there are 2 ways it can twist....:whistle:
Similar threads
