BimblingBee
see other thread
I'm sure I should know but which one?!
see other thread
Too many variables for that (strava) that affect it.
wind direction, gradient, road quality etc.
you should have an indicator on your shifters that shows you what gear you are in.Truth be told, I'm often not sure what gear I'm in and I don't know if I'm using the same ones all the time. I'd love more shifters to tell you what gear your in.
I can't help thinking though that if I could tell strava what wheel size, chain rings and cassette I'm using, then they could use my speed and cadence sensor to calculate what gear I'm in... That would be interesting... In a similar vein, I think di2 systems should have an ant+ transmitter (and profile) to transmit what gear your in for a cycle computer to record.
David
If you use flight deck shifters did you know that you can pull back the rubber and fit a small wiring loom that then connects to the Shimano Flight Deck Computer and shows you what rings you're in? There are a few different types but here's one as an example.Truth be told, I'm often not sure what gear I'm in and I don't know if I'm using the same ones all the time. I'd love more shifters to tell you what gear your in.
David
Just because someone has expensive kit and dressed like a demi god it does not mean that they know what they are doing. Just carry on enjoying the silence!
