Gear sizes for a muppet
DaddyPaddey
Fareham
I think I am being particularly stupid, but don't mind admitting it.
My new chariot has a 11/34 at the back with a Sram Dual Drive3, and the gearing seems a little higher than I expected.
I attacked the Sheldon Brown website which calculated the lowest gear as 21.9 inches, which is exactly the same as my Audax bike. This would be fine.
I understood that the gear inches were how far you went with one revolution of the pedals. I tried this on the chariot and it came out as 65" [and yes I did check with other bike which is about the same]. How have I lost the plot, and what am I doing wrong?
Sharky
Kent
All dates back to a penny-farthing, when the biggest gear you could have was the biggest wheel you could manage, so the convention was just based on wheel diameter.
Cheers Keith
mjr
[QUOTE 3974169, member: 9609"]It would have made so much more sense for gear inches to be gearing x circumference, but for reasons i don't understand it is gearing x diameter[/QUOTE]
Gearing x circumference is known as "development", isn't it?
DaddyPaddey
DaddyPaddey
Fareham
I undertood the bit about the penny farthings. So to get this straight, am I correct in thinking that gear inches do not state how far you have gone on one pedal revolution?
DaddyPaddey
DaddyPaddey
Fareham
I understand now-big thank you. I have always ridden with a high cadence so particularly liked a low gear on the Audax bike. As the new bent has the same 21.5" as the Audax lowest I assume the reason that I am finding it harder is that a) the bent is heavier, b)I can't stand up and c) I haven't yet fully got 'bent legs'
DaddyPaddey
DaddyPaddey
Fareham
absolutely 1st class. I have found it particularly useful when you are not certain which gear you want to be in, at a junction, to be able to drop into the lowest range whilst stationary. Something that usually happens at least once a ride when you don't realise you have stopped on a slight incline.
stuee147
north ayrshire
thanks for that iv been looking at a few different setups the sram duel drive being the main one iv looked at but also the schlump drive combined with a shimano nexus rear hub. i love the cleaner chain lines and easier chain lines too but also the ability to change gear without moving and not forgetting the lower matinace on the whole thing
