Twilkes
I've read lots of stuff about how drops are more aerodynamic than flat bars (even though they're only generally 6 inches lower, not a huge distance, and I can crouch over my flats with my elbows tucked under my chest and not really feel much difference in air resistance). But then the relaxed vs aggressive geometry argument kicks in and I tend to get lost with the different bars and tubes that people talk about. So....
I'm probably moving from a Raleigh Pioneer with the bars about 5cm below saddle height (I'm 6ft5 so the saddle's pretty high), to a Revolution Cross where I guess the saddle will be the same height from the cranks as my Raleigh, and the bars could be set wherever I wanted them, maybe even 5cm below the saddle again. So what is it in the geometry of the frame that says I will encounter less air resistance? Surely if the saddle, crank and handlebars are in the same relative places, the frame has no bearing on anything?
Genuinely curious, as I'm happy on flat bars and was only considering drop bars to make headwinds easier to deal with.
