Get mudguards closer to the wheel
gaz
Cycle Camera TV
South Croydon
So I've got myself a crosser and i've added some full length mudguards, however because i've added 25x700c tyres the distance between the guards and the wheel is a little too much.
I need some kind of plate that I can use to bolt onto the brake bridge and then bolt the guard bracket onto that.
Does anyone know where I could get such a fitting? Looked in b&q but I couldn't find anything suitable.
jonny jeez
too big?
Davidc
Somerset UK
Hello gaz - I solved this by buying some slotted metal bracket things at B&Q, bending the bit of the mudguard bracket that goes upwards to the bridge through 90 deg so it's parallel to the guard, with a bolt through it first.
The B&Q bracket cut down to 1 hole on one side popped over the bolt, and the other side lined up then cut off at bridge hole height.
Finally the remaining bit of B&Q bracket fixed in place.
It worked for me on my last bike - hope it helps. That was when I changed from 27" to 700c rims.
Could do it with any old piece of metal and drill holes to suit.
  • Like
Reactions: gaz
Banjo
Fuelled with Jelly Babies
South Wales
GrumpyOld Git is stood poised with hacksaw and file at the ready. Give him the hole diameters and centers and unleash the dogs of war...^_^
  • Like
Reactions: gaz
Mo1959
  • Like
Reactions: gaz
