Getting a frame re-painted
Skywalker83
Member
evening all.
I'm in the middle of stripping down my old mountain bike (17 years old!!),a Peugot rad forumala. Once it's all stripped I want to get it sand blasted and re painted. And eventually get all new hardware on it. It's an aluminium frame. Anyone got any advice for doing this,anything to be careful about?
Are you going to spray it yourself? If you are you will need to etch prime .
classic33
Leg End Member
Both frames I got repainted, I was lucky. Worked in a place that did shotblasting and also powder coating. It was just a matter of waiting until the right colour was going through and then just hanging it on the track. Second was done at Ellis Briggs, because of a damaged tube.
Drago
Powdercoating can be questionable on alloy frames. The curing process can affect any heat treatment or ageing process the frame may have been subjected to during manufacture.
You want a soft media or soda blast, perhaps a bead blast if the operator is skilled and has a sympathetic hand.
A mate sent his alloy bike for shot blast. The company didn't do bikes often.... The frame came back like a golf ball, and don't mention the carbon forks that were fitted.... Gone...
Make sure they do bikes.
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
If you have a look at this article it might suggest otherwise. The way I read it, the powdercoating cure temperature is very close to the aging temperature of the frame, but for a small fraction of the time.
