Getting crank off
gazza81
Edenbridge
How do i these cranks off, i have a halfords tool that ive used in the past with these cranks have a hole through the centre so the tool doesn't work! 488888
488889
midlife
Does the crank say Octalink on it?
https://forum.bikeradar.com/viewtopic.php?t=12731087
gazza81
gazza81
Edenbridge
It's an octalink so that puller should work. Have you tried it?
Its got a smaller insert and a larger one, the smaller one just goes in with no resistance behind it, the larger one seemed like it fit better but i didntvwant to force it as i wasnt sure if itvwas pushing against anything or if it was pushing on the little tabs inside the crank arm if that makes sence
gazza81
gazza81
Edenbridge
If the head clears the serrations it'll be fine.
Yeah its doesn't quite, tiny bit pushing against them
