Citius
Btw what's with the tyres? That's how they came - already fitted, are they any good?
They look like Corsa CXs - in which case, they're among the best...
Yeah heard that about deep section fronts, I've always got my 30mm superstar clincher that I can put on the front for windy days, bugger to keep swapping pads though!
I think I've used my allowance up for the next 10 yearsBuy another carbon wheel then
You may want to check the tyres are glued on properly if they came like that . The one and only PX tub i have seen from new i managed to roll the tyre off the wheel with my thumb . Ok it wasn't inflated to max pressure but it was inflated , the thin bit of tub tape they had used was doing nothing .Btw what's with the tyres? That's how they came - already fitted, are they any good?
They seem well glued on to me, with bits of glue coming out onto the tyre almost "messy", did wonder if it was tape or glue? Also got a spare used tub with the wheelset which has a very sticky back to it.You may want to check the tyres are glued on properly if they came like that . The one and only PX tub i have seen from new i managed to roll the tyre off the wheel with my thumb . Ok it wasn't inflated to max pressure but it was inflated , the thin bit of tub tape they had used was doing nothing .
Could have been a one off though and easy to check .
Think they are Vitoria corsa sc ?They look like Corsa CXs - in which case, they're among the best...
Cheers, I've no idea, having never used them before! I will check though!Sounds good then . This one was in my LBS being built . They where laughing about it and said they would have to redo it . Just saying for your benefit , no other reason .
Yep stuck pretty well, just lots of gloopy sticky muck round the rim edgeSounds good then . This one was in my LBS being built . They where laughing about it and said they would have to redo it . Just saying for your benefit , no other reason .
Cant really see but they sound glued on . I assumed you bought them new from planet x but with those tubs glued on and a spare it doesn't sound like it . I should know better really ehYep stuck pretty well, just lots of gloopy sticky muck round the rim edge
Yep gumtree "bargain" (or not depending on how knackered they are)Cant really see but they sound glued on . I assumed you bought them new from planet x but with those tubs glued on and a spare it doesn't sound like it . I should know better really eh
Hiya, haven't been on the road with it yet, just been plodding away on the turbo! Job to tell really, but getting used to the position, managed my 20 minute speed test "in position" so can't be bad. The saddle puts a fair bit of pressure on the nether region and I wonder if an Adamo might be the way to go?How are you finding the new bike pal ?
