GPS cycle computer for navigation - recommendations?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Probably me! Do you remember doing calculations on slide rules and using log tables? I was an expert. But my mind balks at the current replacements. I just have to accept the new reality.
Ok, but what was the problem. What was happening when you pressed the start/stop button
blackrat
I suspect the issue may have to do with the proximity of the phone to the Edge. If you only want to use the device's odometer and speed, do you have to have the phone along? Or can it act as a stand alone miles and speed indicator?
ianrauk
Rides Ti2
It works without a phone
You may have pressed the on/off button (without switching it of) which locks the screen.
chriswoody
Northern Germany
You don't need the phone connected to the computer at all for it to function, the Edge Explore 2 is completely stand alone. My phone drains battery really fast when the bluetooth is on, so mostly it's only ever briefly connected to the Explore after a ride to download the data.
For me, if I'm only recording a ride, when I set off I'll switch the unit on, then select the profile I want, depending on the bike I'm riding, so I have Mountain bike or Gravel bike. Then I'll press the button in the bottom right corner to start recording and off we go.
blackrat
Thanks, next ride I'll try that. When I press the start button a screen comes up asking road, etc. selection but also showing 'Navigation' and 'Courses' and 'Group ride' and 'Location search' on the same screen, is that usual? Also, I did find that when I pressed the bottom right button the timer started, which was weird!
chriswoody
Northern Germany
When I switch my Explore on I get the following screen which I think is the one you mean:
I then select the correct profile from the blue bar at the top, so Road or Off Road. Press one of the white arrows or swipe left or right to flick through the three standards profiles, Road, Off Road or Indoor. Then when the correct profile is showing in the blue bar, press the blue bar and this screen then pops up:
Once that screen is up I will then press the start button to record the ride and off I go. Maybe you have questions because you've not selected a profile to ride with?
These are random pictures I just quickly grabbed from the net, my screens are slightly different because I've configured them to suit me and I suspect yours will also show different things, but hopefully you get the idea.
blackrat
Perfect thanks. Nice to know I am on the right road, so to speak.
One issue I have is that with the sun so bright, it is a bit difficult to actually see the screen to be sure it is showing what it is supposed to, so straddling the bike I have to crab walk to seek shade and then I have to squint at the screen to be sure.
blackrat
Okay, sitting at my desk I have selected 100%, hope that works. :bicycle: Thanks.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
No need to do last part. Just press start button, and you are good to go, for the profile you are on.
sevenfourate
Devotee of OCD
Received my Bryton Rider 650 today. It may be a few days before I can get to use it on a ride but it's been easy enough for even a numpty like me to update the firmware, download the app, sync the two devices and associate my Komoot account and upload an existing route to the device. Obviously has a huge amount amount of ride and performance data I'll likely make very little use of. Only thing now is to see how it measures up with navigation, which I'll test on one of my familiar routes first. But - so far, so good; no issues with any of the 'technical side' so far.
Any ‘updates’ (Pardon the pun) on how the Unit is working out for you ?
sevenfourate
Devotee of OCD
Some of the high end, but cheap units like Coospoo are pretty good.
The Coospo CS600 gets great reviews everywhere. Simple navigation, bright touch screen, good battery life blah blah
I’m generally trying to resist electronic / technology ‘clutter’ on my rides (And only normally doing max of 50 mile: loops - I don’t need one). That and I’m c^*p with: and get easily frustrated with modern electronic Tech.
BUT: I feel I should for the occasional longer ride, group rides where I become leader. And I’d like possibly stretch out my riding distances a bit more next year.
I’d also like to maximise my limited cycling / turn some of my rides into Training rides - and link them in to a HR monitor. *Mainly to make my slow rides - properly Z2 slow……🙄
At £100 and change for the head unit, couple of extra out front mounts, a HR monitor, silicone cover etc - I feel I should have tried my luck long ago as it would seem to be a very cheap introduction to GPS navigation……. 🤷‍♂️
