If you can stretch the budget a bit/get lucky with a sale, I'd heartily recommend the Garmin 1040.
Failing that a 2nd hand 1030 would also do the job, and come in under budget.
I've been through Garmin 1030, 1040 (Solar) and now using 1050.
I orginially went Garmin 1030 after mid tour my Wahoo proved a disaster (see post above) so had to get whatever the store had in-stock (which was Garmin 1030 or nothing). Aspects of it are beyond my needs but other aspects are brilliant. For OP/anybody I suspect much depends on budgets.
couple of considerations:
1. I create my routes on
https://cycle.travel and once created just press a button and few moments later the route appears on my Garmin GPS. Very quick and convenient.
2. Re: 1040 Solar (as opposed to just 1040): The "solar" is a film over the screen and it does impact how bright the screen is. Were I to repurchase a 1040 today knowing what I know now it would not be the solar version but the solar one is not a "disaster".
3. If budgets permit the 1050 has an amazingly bright clear screen. Functionality seems not much different from the 1040 but the screen is fabulous (and with it still has excellent battery life).
4. I've found battery life on all I've had to be excellent, always giving me a couple of days cycle touring between charges.
5. One feature I find very reassuring when on tour is that the device can create cycle routes on device (no phone app needed, no internet, all on-device). I used this for 1 month on EU tour and whilst the route were not as good as cycle.travel, they were perfectly good cycle routes. On tour where each evening I create my route for the next day (ie no pre-planning), the on-device capability gives me a reassuring backup in case on no WiFi and no phone signal. But how useful that is depends on how the device is being used.
6. Turn-by-turn directions are clear, the beep as you approach the turn loud enough (you can set the volume) but if you do go wrong of deviate eg "Road Closed" or just something interesting the device will recalculate the route on-device without needing phone or internet.
