Granite Composite sink leaking
MrGrumpy
Huge Member
Fly Fifer
It would appear I have a crack in my sink, anyone repaired one ?? Any type of epoxy resin good enough ? Can get my hands on some araldite epoxy adhesive ? Its for underneath the sink as I can feel and see where its cracked and leaking?
Cycleops
Accra, Ghana
Epoxy would be about the only thing i can think of that would be suitable. Araldite should work okay.
Get it completely dry first perhaps using a hair dryer and push the adhesive up into the crack with a piece of thin ply which you can later remove.
Good luck.
Beebo
Firm and Fruity
Hexleybeef
There are companies that can visit and repair damaged ceramic sinks. Not sure about granite but give them a call.
Bathdoctor is one such company.
MrGrumpy
MrGrumpy
Huge Member
Fly Fifer
Cannot see a crack from the top??? It’s like its gone porous ? I can feel/see cracks rough areas underneath on bottom edges ?? Also water drips and it’s bad enough that there is plenty water lying on the cupboard floor? I have some epoxy araldite adhesive. Along with some epoxy putty. ( had it at work ). Will try that out tonight.
Levo-Lon
Don't DIY this. Get a specialist in. They'll do it invisibly, whereas anything you do will be a visible mess forever. It's standard stuff for them.
What the man said, you'll make hash of it
sheddy
Suffolk
Provided that you can get to the underside, I'd try glass cloth and resin - applied with brush and small roller (V. messy, wear goggles, gloves and cap !)
slowmotion
Quite dreadful
lost somewhere
My guess is that a certain amount of grease will have accumulated in the crack. Simply applying epoxy/polyester resin won't work unless it has a grease-free surface to adhere to. You will probably need to rake out the crack and make good, top and bottom, after the filler/adhesive has cured.
Well, that's what I'm guessing anyway….
