Greenhouse anchorage
Sharky
Kent
Just ordered an alu greenhouse. Any tips for anchorage? It can get quite windy down here in wild Kent.
Have seen various kits, but don't know which work well.
Any suggestions would be appreciated.
Thanks
Bonefish Blues
Banging donk
52 Festive Road
Looks in vain for Alaska images.
Wanders off :unsure:
Levo-Lon
What's it going to stand on?
If it's a windy exposed area.
I'd opt for a small footing where frame will go and a course of engineering brick then screw frame to the bricks or use a waterproof adhesive, like gripfill .
Footing would only need to be 150mm deep by 100mm wide
You could use slabs also
Sharky
Sharky
Kent
Initially thought we would just put it at the end of the lawn. Planning on making it level and putting a weed membrane down and then putting pebbles/gravel inside the green house and a border round it, with paving slabs down the middle.
A bit like this
513748
tom73
Yorkshire
It will need some form of ground anchor as @Levo-Lon says. If the wind get's it then it will go over or worse.
I'm lucky mine won't move come what even without the inbuilt ground anchors concreted in.
Then again it's not your average off the shelf one.
Levo-Lon
A bit like this
Nice greenhouse if that's what you bought.
You could do that but I'd strongly recommend at least 4 concrete anchors.
Dig 4 holes or one at each angle tho 4 should be fine
Anchor would need to be about a bucket full of concrete.
Anchor greenhouse and cover with gravel, sorted
You can get a variety of masonry bolts , expanding wedges and self tapping bolts. Thunderbolt seems to be biggest branded fixing.
keithmac
Google "ground screws", probably easiest way if you're building it over soil.
