Archie_tect
De Skieven Architek... aka Penfold + Horace
- Northumberland
I know, but it's worth it.Epoxy grout is an absolute nightmare to use! Blooming expensive too.
You spend more time cleaning your tools than doing the job.
also works on the blackened silicone around the bathtub tooBuy a big a bottle of Domestos bleach and a few rolls of lavatory paper. Twist a couple of sheets of lavatory paper into a "snake" and dip it into the bleach until it is soaked. Then press the snake against the mould on the grout. It helps if you mash the snake into a pulp in-situ. The idea is to keep as much liquid bleach against the mould as possible for as long as possible. I leave it for about an hour. Repeat as necessary. It really does work!
BTW, undiluted bleach can give you dermatitis, so try and keep it off your hands. Top Tip @Drago: wear a pair of pink Marigolds and lock the door to spare you from embarrassment.
And when the grout is done I can use the same get up for my dangleberrys.
This man knows the score @Drago , do this!Buy a big a bottle of Domestos bleach and a few rolls of lavatory paper. Twist a couple of sheets of lavatory paper into a "snake" and dip it into the bleach until it is soaked. Then press the snake against the mould on the grout. It helps if you mash the snake into a pulp in-situ. The idea is to keep as much liquid bleach against the mould as possible for as long as possible. I leave it for about an hour. Repeat as necessary. It really does work!
