bad luck Garilla. thank god you were not on your way to work
Funnily enough I stsrted a thread about carp patch adhesive last w/e . I'm sure that the formulae has changed due to EU legislation (glue sniffing problems)
At least in the old days if you couldn't fix your P&%$£2* you could sit under a tree and sniff your glue
Have you looked at the tubeless tyre options ?
and the faff to get the back wheel off meant he would rather put up with the choppy ride than spend an hour fixing a p***t**e
